Perform the following procedure to view Node Alias DHCP fingerprint information.
- Select Node Alias.
- Select the DHCP Fingerprint tab.
DHCP Fingerprint Field Descriptions
Use the data in the following table to use the DHCP Fingerprint tab.
Name |
Description |
SourceMacAddress |
Displays the source MAC address. |
Isid |
Displays the I-SID. |
Vlan |
Displays the VLAN ID. |
Isid Value |
Displays the I-SID value of the I-SID-to-VLAN assignment. |
InterfaceIndex |
Displays the receiving port or MLT interface. |
Ipv4Addr |
Displays the last known IPv4 address of the client. Note: Option 53 reads the IP address.
Option12 |
Displays the hostname of the client received from the DHCP server. |
Option55 |
Displays the list of configuration parameters the client requests. |
Option60 |
Displays the vendor class domain name. |
